Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Turner Lower Rear Shock Mounts
Reply
      05-17-2018, 06:50 PM   #1
dleccord
Drives: 2011 BMW 335i E90
Has anyone tried the monoball design?
https://www.ecstuning.com/b-turner-m...024572tms03~a/
      05-18-2018, 03:14 AM   #2
Kevin_The_Clean1
Kevin_The_Clean1's Avatar
Drives: 2020 X3 MC
I'm going the full E9X M3 conversion route back there. But I must say that these look excellent...
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten
2011 E90 335i M-Sport - Daily Driver
2017 F87 M2 - Sold & missed
2020 + 2024 F97 X3 M Competition (slick top) - Finally arrived ///
      03-12-2019, 10:27 AM   #3
Yangorang
Drives: 2008 BMW 328xi
Bump - anyone tried either the upper or lower monoball mounts from Turner and have any feedback regarding NVH?
https://www.ecstuning.com/b-turner-m...0019tms01~arw/
      03-15-2019, 01:28 AM   #4
hellokitty
hellokitty's Avatar
Drives: '17 M3 ZCP DCT
I use the AKG upper and lower rear mounts. No NVH.
I also have aluminum subframe bushings. No NVH.
      03-15-2019, 05:26 PM   #5
Yangorang
Are you using the poly lower mount or the spherical bearing one?
AKG rates the spherical bearing ones for track only but I would think them being at the bottom of the shock it shouldn't be as big of a deal as the top mount.
      03-15-2019, 06:04 PM   #6
hellokitty
hellokitty's Avatar
AKG poly for rear bottom.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race
      03-15-2019, 08:43 PM   #7
Yangorang
Have you had to grease your poly mounts to prevent squeaking?
      03-16-2019, 12:28 AM   #8
hellokitty
hellokitty's Avatar
No haven't had them installed long enough to hear anything. Only had them for a few thousand miles.
      06-29-2019, 11:11 PM   #9
dleccord
update for those who are looking into this as an alternative upgrade/replacement in the future. the lower mounts are fine but because they're designed the way they are, expect higher rates of upper shock mount failures. i just went through a set of dinan upper shock mount kit (12mm) for my tc kline shocks.
      06-30-2019, 09:49 PM   #10
Asonchadwick
Sleepy
82
Drives: bmw
I wonder how it's ruining the top mounts. Turner also makes a top mount like the bottom. Maybe you need to run both?
Reply
