BMW 3-Series (E90 E92) Forum > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > E60 525i: strange codes
Reply
      09-17-2024, 08:41 AM   #1
havar
Drives: f80
I have a 525i 3.0L N53.
I had some headaches for the misfires so spark plugs, ignition coils and valve cover gasket have eventually been replaced.
However two codes still show up together: one is for the map thermostat activation (2EF7) and the other one is for NOx heating.
Before starting replacing this and that, I am thinking about checking thermostat first as I read that if it fails to close, the car runs cold, therefore more fuel thrown in and nox triggered. I didn't check the temp gauge. If that is ok, I would have to go and check the nox then.
Car has undergone a thorough refurbishment in the last few months and drives very smooth apart from an intermittent EML light which warns about a lean condition on bank 2 (which might be nox-related to probably due to the car running in homogeneous mode?)
Any suggestion would
Reply
