07-17-2024, 04:12 AM | #1 |
Rep 4
Hello I want to know who or what is the best HPFP I keep seeing TU HPFP but not sure what that means. I want to go stage 2, I am currently cattless downpiped stage 1 and want to know what the best brand or kind of HPFP to get for my car or any other upgrades I should do before I go stage 2. I would also like to know if I should get a muff delete, I currently have both res delete but friends tell me I should go muff delete as well. I’m very new to the car community and need some help.🙏
07-17-2024, 08:00 AM | #2 |
Rep 1,966
Stage 2 only requires a high flow downpipe, that's it. Upgraded fuel pumps are for running ethanol or big turbo. The TU pump is the supra or G chassis pump, so it's OEM but has a higher flow capacity. There are other aftermarket brands like Dorch with higher flow capacities. Muffler deletes always sound like garbage, but if that's what you want, go for it.
22savage0.00 |
07-17-2024, 08:52 AM | #3 |
Rep 363
definitely do not go with a muffler delete. If you really want that more refined and slightly more aggressive sound, definitely go with an axleback (like remus) added onto what you currently have. should sound great.
Just like freakstyly said, you are good to move onto stage 2 ots maps as they only require a high flow downpipe. Only stage 2+ requires the hpfp. I highly recommend going with Dorch if you want a direct fit plug and play solution when it comes to the install. If you're comfortable with bending your fuel lines, I recommend the fuel it pumps. |
22savage0.00 |
