Michelin PSS 225/40 ZR18 92Y XL vs stock 225/40/ ZR18 88Y |
04-01-2017, 04:25 PM | #1 |
Rep 566
I came across the information on the Michelin website that there are actually 2 versions of the Michelin Pilot Super Sport tire in 225/40/18 size.
The one that comes from factory (BMW) is 225/40/ ZR18 88Y. There also exists 225/40 ZR18 92Y XL. I wonder if on a staggered setup (225/40/18 front 245/35/18 rear) replacing the stock front tire with the one that has a higher (92) load rating and XL sidewall (probably/hopefully more rigid) will have a significant effect on a) outside tread premature wear b) understeer c) handling of the car in general. Any suggestions? |
04-01-2017, 08:05 PM | #2 |
lieb923
Rep 49
Drives: '15 M235Xi
You want the tire with the star on the sidewall, It's the BMW spec tire.
If you don't need immediate replacement i'd wait for the PSS4S they are in the process of releasing them. the specs are improved. |
04-01-2017, 08:14 PM | #3 | |
Rep 580
c) If the sidewalls are stiffer with a 92XL rating ,turn in should undoubtedly be better. |
x233284.00 |
04-02-2017, 05:41 AM | #4 | |
Rep 566
What I would like is a) a tad bit grippier front tire, b) a bit less outside wear, c) a bit sharper steering. I wonder if that tire can help that or not. |
04-02-2017, 01:39 PM | #5 | ||
Rep 851
No detectable difference at least for me. There is certainly no issue with driving with the higher load rating. I am also driving with front pressure up to 35/36 PSI to mitigate understeer and wear. Not sure if that helps any either.
Hoc Lapidem Non Vi Sed Saepe Cadendo!
04-02-2017, 07:40 PM | #6 | |
Rep 566
ps: I, too, run higher front tire pressures. plus, I made a little less toe-in (0.04 instead of 0.07). |
04-12-2017, 01:05 PM | #7 |
Rep 2,924
I've seen several comments that the best, perhaps only fix for that outside scrubbing is more camber, especially via the 4-series lower control arms - not sure you can do that to an x-drive, though.
04-12-2017, 05:56 PM | #8 |
Rep 851
You cannot.
04-12-2017, 09:42 PM | #9 |
Rep 566
Just an observation: the stock 225/40/ ZR18 88Y Michelin PSS tire has a kind of slanted/sloped outer edge when completely new, tread on the outside already not as deep as on the inside, plus the soft outside sidewall, so no wonder it has an issue with premature outside tread wear.
04-13-2017, 11:53 AM | #10 | |
Rep 3,841
Anyone worried about handling and tire wear might consider getting an alignment even if you haven't hit any major pot holes. Although my stock staggered setup lasted 13,000 miles, the front and back tires were ground on the outside corners while the center and inside still had a lot of tread, I guess like all of these cars :-(. I'm curious to find out if the Dinan springs, new alignment and new MPS4 S tires will make any difference in wear pattern...fingers crossed. It definitely feels like the front has less plowing into corners now. Last edited by AlpsRider; 04-13-2017 at 11:59 AM.. |
04-13-2017, 12:45 PM | #11 |
Rep 2,924
So are you are noticing changes just from the improved alignment, or did you add the parts too at the same time? In other words, was that a noticeable improvement for driving?
04-13-2017, 12:57 PM | #12 |
Rep 3,841
Unfortunately, I added the wheels, tires, Dinan springs and alignment done all at the same time. Also, because of the Dinan springs the front negative camber is at -1.0 now, hopefully that will help with front tire wear a bit.
04-13-2017, 07:38 PM | #13 |
Rep 566
I ran Pirelli P Zero last season and the fronts (225/40/18) were wider than the Michelins of the same size, their outer edge is more "square" and the sidewall is definitely stiffer. I didn't notice nearly as much outside wear with a more conservative alignment as it is now with the Michelins. and I've only had the Michelins for about a month but I can already see the scrub marks on the outside oh so clearly. The Michelins are certainly more comfortable, though. Stickier? Probably. At least in cold temperatures. Too early to tell, though, since we haven't had really warm weather yet but there's less understeer and the car feels more agile in tight corners or when changing direction. Wheel alignment is not an expensive procedure where I live so I do it 2-3 times a season, either to fine-tune the handling characteristics or just in case... and yes, every time it's a bit off from what it was set to be on a previous alignment.
06-23-2018, 09:29 PM | #14 | |
Rep 566
The 92Y XL version is about 5 mm wider than the 88Y tire when put side by side. Also, the 88Y has a kind of slanted outer edge even when completely new so it looks kind of used even if it's never done a single mile. The 92Y XL version does not have that and its outer edge is more solid and square. The 92Y XL feels a bit heavier. I think that maybe BMW chose the 88Y tire because it's more comfortable and lighter. I can feel it on less than perfect roads, it's not too much to make a fuss about it but it's certainly there. The steering is a bit heavier and a bit more planted, a bit more direct, the difference is not huge but it's there. There is less of that empty feel at the steering wheel that's present with the 88Y front tires. The car is a bit more planted at high speeds, too. Having said that, I think that maybe the BMW-specced (softer) tire is still a better choice for the city for most people because it's more comfortable and refined. The front end (with 92Y XL tires) is a bit more stable/planted when cornering hard and now it feels like the rear begins its sideways slip earlier than before - there is less understeer (maybe it would be less noticeable if the rears were completely new, too). I used to run higher pressures for the fronts and now I run equal front/rear tire pressures. I would actually prefer to have a bit harder rear tires now Last edited by x233; 06-23-2018 at 09:43 PM.. |
07-23-2018, 12:12 PM | #15 |
Lucky13
219
Rep 1,765
My 88Y fronts were shot at 6,000 miles and I only do 1-5 mile city trips. Got an alignment at 6,000miles and no adjustments they were in spec. I actually beleive that a lot of city driving with a lot of turns just kills these fronts. Just ordered the 92Y’s from my dealer since the rears are 92Y anyway. Dealer agreed to go none spec because of the wear problem. Checking the 4S specs shows they are 92Y also for fronts. At 3-4,000 miles I started keeping them at 35-36 psi to extend the wear but I’m completely through the tread into the belt on the right front at 13,000 (2014 model all city driving). My rears could probably go another 10,000 but I’m replacing them. BMW has a special going so I’ll give the PSS another shot and Costco was a 2 week wait for the 4S.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
07-26-2018, 07:28 AM | #16 | |
Rep 162
I'm sure there are other differences too, as you have mentioned. |
07-27-2018, 06:26 PM | #17 |
Lucky13
219
Rep 1,765
I talked to 3 different people at Michelin and they really need some people in customer service that can read a spec sheet or answer basic questions. The net of 3 conversations was 3/10’s of a pound heavier, 10/32 tread depth vs 9/32 for 88Y and slightly thicker side wall. Don’t kill the messenger this is the only consistent answer I could get but who knows if its true. Like I did point out earlier, the new 4S is 92Y also for the fronts so it will probably be a little stiffer ride than the 88Y MPSS also.
11-17-2020, 08:27 AM | #18 | |
Rep 1
11-18-2020, 04:59 PM | #19 | |
Rep 566
