Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Raj's 335i - The Build (Updated Pics)
Reply
      03-22-2015, 03:06 AM   #155
old grey steve
old grey steve's Avatar
United Kingdom
295
Drives: MK 7.5 Golf R
You don't stop do you Raj, gotta say this is or appears to be a superb addition you were very lucky it would seem to obtain the system. You're gonna have to put a sound clip up
      03-22-2015, 05:02 AM   #156
mob17
mob17's Avatar
United Kingdom
426
Drives: E92 335D
You're building something special here Raj.
Never realised you had an LSD! Massive improvement over stock handling, been dying to get one for ages.
      03-22-2015, 01:44 PM   #157
borinous
borinous's Avatar
43
Drives: E90 320d SE
Looking good pal look forward to more updates
      03-23-2015, 03:24 AM   #158
RajB
RajB's Avatar
485
Drives: E92 335i
Originally Posted by garysan View Post
Liking this
Cheers, I aim to please
Originally Posted by 2die4 View Post
Awesome build thread and car! Some fantastic subtle mods which make it unique. You must be very happy with the progression. Can't wait to see future posts....
Thanks. I'm loving how it's coming together. Next mod currently 'partly' being sorted as the next bit to it is expensive lol
Originally Posted by JM85 View Post
Very nice, love what you've done
Loving the 313's, would like a set for my E90
Cheers. I do love the 313's BUT am starting to look at my next set of rims...lol
E92 335i / M3 Hybrid - The Build
      03-23-2015, 03:25 AM   #159
RajB
RajB's Avatar
485
Drives: E92 335i
I do have a bit of an addiction lol. I think in part it's I have an end goal and pretty much just go for it. But the other thing is bits I've been after or wanted have come up sooner rather than later so forced my hand a little.
      03-23-2015, 03:27 AM   #160
RajB
RajB's Avatar
485
Drives: E92 335i
Thanks. And yes the Quaiffe was already fitted
It's kind of unique but not either lol as in a way kind of looks like Sam's old look lol. Most of my mods are more functional generally along with a few visual differences.
      03-23-2015, 03:28 AM   #161
RajB
RajB's Avatar
485
Drives: E92 335i
and the wait shouldn't be too long lol
      03-23-2015, 03:59 AM   #162
borinous
borinous's Avatar
43
Drives: E90 320d SE
thats what i like to hear....even if they do make me horrendously jealous
      03-23-2015, 04:01 AM   #163
richk84
England
141
Drives: e93 330i
Whens that roof getting fitted!
      03-23-2015, 11:25 AM   #164
RajB
RajB's Avatar
485
Drives: E92 335i
It's not what my bank manager (wifey) likes to hear though lol
      03-23-2015, 11:26 AM   #165
RajB
RajB's Avatar
485
Drives: E92 335i
That's on hold at the mo as I keep getting side tracked. First the Alcons, now the Akra and then the discs/pads for the Alcons LOL
      04-14-2015, 04:47 PM   #166
RajB
RajB's Avatar
485
Drives: E92 335i
Not much progress of late. Couple of things in the pipeline so just a small update.
A set of RPI scoops kindly purchased from Greg:
Really good condition so a proper bargain
I like the BMW Performance decals Greg added
Nice and subtle behind the grilles
      04-22-2015, 11:50 AM   #167
Greg330
Greg330's Avatar
70
Drives: E91 335i
Glad you're pleased!!
I think they are a must....
      04-22-2015, 04:08 PM   #168
Ess
Ess's Avatar
United Kingdom
84
Drives: E92 335d
Looking good Raj. Can we have a full front end shot showing the new scoops please?
Ess
2009 E92 335d M-Sport
1990 E30 2.8 m52b28 conversion
      04-22-2015, 04:55 PM   #169
AWBimmer
AWBimmer's Avatar
United Kingdom
387
Drives: E91 330i Monacoblau
+1
BMW E92 335D | Lower Klasse
IG: @that.m6
      04-23-2015, 08:09 AM   #170
RajB
RajB's Avatar
485
Drives: E92 335i
Will do but not much to see as they are black so nice and discreet.
      05-03-2015, 05:03 PM   #171
RajB
RajB's Avatar
485
Drives: E92 335i
So I never got a better front end pic of the scoops, but instead finally got round to fitting the M3 front arms.
Took me a few hours as was taking pics and generally taking my time lol.
First off here are the front M3 control arms in all their glory:
Here's links to the arms I purchased:
https://spareto.com/products/jtc1426-track-control-arm
https://spareto.com/products/jtc1427-track-control-arm
https://spareto.com/products/jtc1423-track-control-arm
https://spareto.com/products/jtc1424-track-control-arm
And the M3 levelling arm part number is 37142283867 and the additional nut 07129904876.
To start with, jack up the car (i used my Arcan trolley jack at the centre front jacking point).
Wheels off and a pic of the front original control arm in place (you can see the end is tucked behind the arch liner):
Using an 8mm socket remove the small bolts that hold the front section of the wheel arch liner in place. There is one 10mm plastic nut too.
With the arch liner out you can see the end of the arm and the bolt that holds it in place (there is a captive nut on the other end of that bolt so makes it easier to remove the bolt):
A quick pic of the rear original control arm (the under tray does cover the end of the arm so if you just remove a few of the 8mm bolts you can pull the under tray down when you need access):
Here's the balljoints for both arms connected to the hub (front arm bolts downwards and the rear one upwards):
I now started actually getting on with swapping the arms out so removed the levelling sensor arm. You need the M3 levelling arm and a single extra nut as the original one is clamped to the rear control arm (as you can see in the pic) whereas the new one is bolted on. To remove you need a 10mm spanner/socket and a 9mm to hold the ball in place:
Once the levelling arm is off remove the rear control arm.
The rear control arm balljoint is held in place with a 21mm nut. To undo you need to use a T40 to hold the balljoint straight while undoing the nut otherwise it will just spin the joint at the same time:
Bit of a shake of the hub and if needed a small tap with a hammer and the balljoint will drop out.
To remove the bush end you need to remove the nut/bolt (18mm both the nut and bolt). Needed to tap the end of the bolt to actually get it out. The end of the steering rack looks like it blocks the bolt but you can lift it a touch. for some reason didn't get a pic of this...hmmm.
To remove the front control arm you need to do the same on the balljoint side (use a 21mm spanner and a T40 socket). The bush end is held in place with the 18mm bolt and the captive nut.
Captive nut:
And the 18mm bolt removal:
Both arms out and sat next to their M3 counterparts (you can see the different connection for the levelling arm to the control arm):
You'll notice that the M3 arms use proper balljoints at both end too.
To fit the M3 arms, it's just the reverse of the removal process above. So I started with the front control arm and put balljoint end into the hub first and then squeezed (using a mallet/hammer) the subframe side in place. It is a little time consuming trying to get it lined up so you can get the bolt back in:
Then onto the rear control arm. This time I put the subframe side in first and I can tell you it was a pain. The subframe metalwork is solid so you can't just pry bar it apart to get the arm in. Took a lot of hammering etc to get it in and lined up. Don't forget to put the levelling sensor bracket onto the end of the bolt before putting the nut on:
Finally both in place (don't forget to bolt the levelling sensor arm in too):
One thing to remember is that before tightening up the nuts/bolts etc on the subframe side, you need to put the suspension etc under load so that the balljoints are straight. With the wheels still off I used a breeze block with a piece of wood on top under each brake disc and lowered the car onto them. Then tightened the nuts/bolts up.
After that is was just a matter of putting the arch liner back in place and bolted the under tray up. Wheels back on and job done.
Just need to get an alignment done now.
      05-03-2015, 06:18 PM   #172
old grey steve
United Kingdom
295
Excellent write up Raj just as you know I was looking for mine will get done in the next week or so only thing I'm missing is the M3 light level sensor
      05-04-2015, 01:29 AM   #173
RajB
RajB's Avatar
485
Drives: E92 335i
Cheers Steve. Will post the part number shortly for the levelling arm. Don't forget an extra nut too.
      05-04-2015, 02:59 AM   #174
old grey steve
United Kingdom
295
im nuts enough don't need another one
      05-04-2015, 03:29 AM   #175
RajB
RajB's Avatar
485
Drives: E92 335i
Think I'm far worse lol
      05-04-2015, 05:00 AM   #176
RajB
RajB's Avatar
485
Drives: E92 335i
This is the part number for the levelling arm: 37142283867
Reply
