BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > CIC/NBT FSC Generator - Windows/Linux/OSX
Reply
      02-19-2026, 10:25 AM   #1365
shawnsheridan
Supreme Allied Commander
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Originally Posted by Tresfal View Post
Shoot my good sir,, I extracted the file modified the lookup to lookup.xml and use the VIN to look up after the update. for F25 X3 NBT
im going to try to attempt again today. Im on windows.
FSC Generation by VIN does not work. Must use 1B/DE File from Head Unit.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      02-20-2026, 11:46 PM   #1366
TechFreak
Drives: BMW 740D
Originally Posted by shawnsheridan View Post
Your PM function is disabled. Send one when enabled.
Hi, I've PM'd you on Bimmerfest Forum as I'm also a member on there. Thanks.
      02-21-2026, 04:48 AM   #1367
shawnsheridan
Yes, I replied there already.
      03-01-2026, 09:56 AM   #1368
MisterrMoon
Drives: 2018 BMW X3 M40i, 2014 BMW 320
Hey Shawn, ive recently retrofitted NBT to my F30 Non-Nav CIC and it works great! but nav is a issue, ive found this FSC generator tool but i dont have a FSC file that contains my VIN as it was previously non-nav! i have the donor vin FSC file saved just incase before i wrote my actual VIN onto the headunit. however when i try to generate a FSC code with this generator im only getting a Speech Recognition (A8) FSC code and not a Navigation (DE) FSC Code which is causing the FSCStatus to Reject! how do i go about this working? i have 7 days before PM's are unlocked.
      03-01-2026, 10:27 AM   #1369
shawnsheridan
FSC Generator makes only Map FSC Codes, and A8 is North America NEXT Map. For NBT Retofit, you need to patch NBT and load a full set of VIN Matching FSC Codes, not just a Map FSC Code. Your PM function is disabled. Send one when enabled.
      03-01-2026, 10:33 AM   #1370
MisterrMoon
Ah, i see. one last question when i injected my cars VIN into the Donor HU does this ruin the ability to do this? also when you mention patching NBT what do you mean by this? im new to this whole retrofitting stuff.. Thank you in advance. ill PM you when it enables!
      03-01-2026, 10:41 AM   #1371
shawnsheridan
You write car VIN to NBT, use aftermarket patch solution, which is what allows custom FSC Codes to be used, and load a full set of custom FSC Codes.
      03-09-2026, 12:41 PM   #1372
triumph123
Drives: bmw x5 35d
My VIN is 5UXKS4C58F0J98545 (F15) NBT
Current maps are "Road map North America Next 2014-2A"
Any help would be much appreciated.
Thanks
      03-09-2026, 04:57 PM   #1373
shawnsheridan
Thanks
      03-19-2026, 02:03 PM   #1374
kasundk
Drives: BMW
Hi
VIN: WBA12AB0505P12649
Head Unit: EntryNav Evo (HU_ENTRYNAV2)
Vehicle: BMW X1 F48 LCI (2019)
I-Level: Recently updated to latest ( F056-26-03-519)
Issue:
Navigation and map FSC (0115 / 0130) are currently rejected after dealer programming.
Please help me with the new FSC set compatible with current head unit (post I-Level update)
0115 – Navigation
0130 – Map activation (lifetime if available)
Note:
Head unit is original (not replaced).
      03-19-2026, 03:43 PM   #1375
shawnsheridan
Originally Posted by kasundk View Post
Hi
Issue:
0115 – Navigation
Note:
PM sent.
      03-24-2026, 12:09 PM   #1376
edvardsk
Drives: bmw 340i
Hi Shawnsheridan,
Any chance of generating an FSC code for F30 340i 2016 - ID4 K467683 please ?
It's for Europe EVO 2025-2 map.
Any help is most appreciated. Thanks.
      03-24-2026, 12:11 PM   #1377
shawnsheridan
Originally Posted by edvardsk View Post
Hi Shawnsheridan,
      04-04-2026, 12:11 PM   #1378
wgreenidge
Drives: BMW 335xi
Hello great info on here been readin two nights ...
ok so i have an 2010 335xi with CIC road map premium 2009
swid reader says no response from control unit after confirming connection and reading vin
Starting...E-serie...
Ediabas version: 7.3.0
Ignition: = OKAY
Trying...
Reading CAS...
CAS: VIN - E270612
Setting addresse: = OKAY
Reading CIC...
CIC: VIN - E270612
System.Exception: IFH-0009: NO RESPONSE FROM CONTROLUNIT
Total bytes: 0
      04-04-2026, 12:13 PM   #1379
shawnsheridan
Ignition: = OKAY
Trying...
Reading CAS...
CAS: VIN - E270612
Reading CIC...
CIC: VIN - E270612
Total bytes: 0
I have no idea on this error.
      04-04-2026, 12:32 PM   #1380
Monk1el
Drives: х5
Hi everyone,
I’m new to the forum, so apologies if this has been discussed before.
I have a BMW X5 G05 with MGU (ID7), originally from the US. The car has already been partially converted to EU (coding), but I’m stuck with the navigation.
Current situation:
* VIN: 5UXCR6C03L9C87353
* Headunit appears to be EU-coded
* Europe LIVE maps are prepared on USB
* Navigation (including map in instrument cluster) is not active
From what I understand, standard FSC generation may not work due to the VIN/region mismatch.
Could someone please advise what the correct approach is in this case?
Is it possible to generate a valid FSC for Europe LIVE, or is a full conversion FSC required?
Any guidance would be greatly appreciated.
Thanks in advance.
      04-04-2026, 12:39 PM   #1381
shawnsheridan
Originally Posted by Monk1el View Post
Hi everyone,
Current situation:
Thanks in advance.
Unit must be patched and a full set of custom FSC codes loaded. You cannot do it yourself.
      04-04-2026, 09:37 PM   #1382
wgreenidge
Drives: BMW 335xi
Yes I had no idea what I was doing. Well I finally got the !bt file using another useb I got the lon liftime number and I was able to load 2023 maps ... perfect this was a great help
      04-05-2026, 01:46 AM   #1383
shawnsheridan
Reply
