BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > CIC/NBT FSC Generator - Windows/Linux/OSX
Reply
      11-09-2024, 09:17 PM   #1057
shawnsheridan
Supreme Allied Commander
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Originally Posted by davidisurf View Post
Doing some research, looks like because my CIC is not on the latest version C1A, things don't look good, it's current on C13 which seems to be 2 versions prior to the C1A.
Anyway Shawn, my car is a 2006 E60 M5 which came with a CCC unit.
Could you give me some guidance for this? So far I found a bunch of different information, mostly different ways to pull the 1b file and generate the FSC for the map, but none that would help my case I guess then.
I was so happy with the whole CIC retrofit installation, I was already thinking about doing the combox as well :/
Car did not originally have a CIC. You can use Donor CIC with its Donor FSC Codes and an Emulator / Activation module, or patch CIC and load a full set of custom FSC Codes, in which case you need to flash CIC to C1A.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      11-10-2024, 07:30 AM   #1058
davidisurf
Drives: BMW E60 M5
Yeah, I was really hoping to find an "easier" solution than doing an CIC update as I don't have an ICOM and I'm not planning on investing in one, there are cheap ones out there but you can really trust these Chinese things. Not only that, also I'd need a good power supply.
      11-10-2024, 09:44 AM   #1059
shawnsheridan
So flashing is not an option. Do yourself a favor and just use an Emulator / Activation module.
      11-12-2024, 03:42 PM   #1060
Bohdan
Drives: BMW 320 E91
Hello!
Please help in generating FSC code
VIN WBAUX31060A663674
Will there be any problems when installing navigation maps on the CIC with old software?
      11-12-2024, 06:54 PM   #1061
shawnsheridan
Originally Posted by Bohdan View Post
Hello!
A663674 is on E89X-09-03-510 firmware which is very old, and does not support Map update via USB.
Bohdan0.00
      11-13-2024, 08:09 AM   #1062
Bohdan
Drives: BMW 320 E91
What can you advise in this situation? What are the ways to update the maps?
      11-13-2024, 11:33 AM   #1063
shawnsheridan
If it was mine, I would update CIC firmware and install latest 2025 via USB. Short of that, you would have to find an old DVD specific version of Map to install.
Bohdan0.00
      11-13-2024, 01:05 PM   #1064
Bohdan
Drives: BMW 320 E91
Thanks for helping.
Is the CIC update done using BMW ICOM with MOST adapter or are there other ways? Sorry, I couldn't find a description on the forums.
      11-13-2024, 01:14 PM   #1065
shawnsheridan
Thanks for helping.
Yes. Then Program whole car with ISTA/P or flash CIC with WinKFP and latets SP-Daten.
Bohdan0.00
      11-13-2024, 01:15 PM   #1066
Bohdan
Drives: BMW 320 E91
Thanks for helping.
I don't even have a line with the firmware version in the CIC menu, when you can update it using USB.
      11-13-2024, 01:16 PM   #1067
Bohdan
Drives: BMW 320 E91
Thank you very much and have a nice day!
      11-13-2024, 02:21 PM   #1068
shawnsheridan
      11-18-2024, 04:57 AM   #1069
Heisenberg13
Poland
Drives: BMW
Road Map Europe MOTION West 2024
Hello shawnsheridan
i am trying to update my BMW E84 CIC MID S606 with Road Map Europe MOTION West 2024 but, I cannot find fcs generator for CIC MID.
Maybe you can help me with a FCS code: this is my vin WBAVM91050VT66601
Thank you!
      11-18-2024, 06:47 AM   #1070
shawnsheridan
Originally Posted by Heisenberg13 View Post
Hello shawnsheridan
Thank you!
FSC Generator Link in Post # 1 works fine for MOTION Map.
      11-21-2024, 11:00 AM   #1071
sorag13
Drives: BMW F11, BMW F01
I can't get 1b file. Tried different USB - nothing.
Tried installing Premium NAV, but also didn't read USB. I was successful with map type "NEXT" because it was old version also "NEXT".
But after install it asks me for code - but I can't choose "Select date" after entering VIN. Tried without date - wrong code.
Also tried to get code via BimmerCode - but this file can't be read by program.
Full VIN: WBA3K11030F847469
Maps: Road Map EUROPE EAST Next 2024
Anyone can provide code? If can't send PM, let me know in email:
sorag13@gmail.com
      11-21-2024, 11:18 AM   #1072
shawnsheridan
sorag13@gmail.com
You have NBT Head Unit. It does not have a 1B File. PM sent.
      11-22-2024, 07:13 AM   #1073
sorag13
Maybe it's possible to generate new correct 20-character alphanumeric code?
I have pulled my code via BimmerCode and I have 24 character number. As far as I know 4 characters are not needed, but I need correct working 20 character code.
      11-22-2024, 07:45 AM   #1074
shawnsheridan
PM sent.
      11-26-2024, 09:51 AM   #1075
euromantas
Drives: F11
Hello guys! Anyone can get FSC code? I cant found.
Map: Road_Map_EUROPE_EAST_Next_2024
Navigation: NBT
VIN: GZ75069
      11-26-2024, 09:52 AM   #1076
shawnsheridan
Navigation: NBT
VIN: GZ75069
Your PM function is disabled. Send one when enabled.
      11-26-2024, 09:58 AM   #1077
euromantas
Drives: F11
Navigation: NBT
VIN: GZ75069
I need make enough posts and wait 7 days i cant guys im stuck in europe. If you can write in my email : euromantas@gmail.com
      11-26-2024, 10:01 AM   #1078
shawnsheridan
Navigation: NBT
VIN: GZ75069
Sorry, I do not send emails.
Reply
